somewhere elseBBK 73mm worth buying or should I invest that money else where?
+1somewhere else. Since some of the FI units reuse the stock one, there is no reason to buy the 73mm.
Put that money into something awesome!
Agreedsomewhere else. Since some of the FI units reuse the stock one, there is no reason to buy the 73mm.
If you want to accelerate faster, regear the rear end.What should I put that money towards then? Trying to make my pony accelerate faster
---------- Post added at 05:07 PM ---------- Previous post was at 05:06 PM ----------
Already have a airaid CAI, flow master exhaust, and a bbk tuner
+1If you want to accelerate faster, regear the rear end.
Lcas = lower control armsCan you guys break down the terms? I'm a noob! I have a auto btw
Thanks! Hmmm now I'm wondering how much more will these costsvilla00 said:Lcas = lower control arms
Uca= upper control arm
4.10 gear = is the rear axel gear. 4.10 means the gear turns 4.10 times to fully rotate the cars rear wheels once. 3.73 for example would mean for every 3.73 times the rear gear spins the rear wheels fully rotate.
Gears installed should be around the same price as a TB to purchase. I would check AmericanMuscle for some more opinions and reviews.Thanks! Hmmm now I'm wondering how much more will these cost
Thanks! You been very helpfulsvilla00 said:Gears installed should be around the same price as a TB to purchase. I would check AmericanMuscle for some more opinions and reviews.
I would go with 3.73 or at most 3.90 not 4.10 ur cars mpg will go down the drainThanks! You been very helpful
About $150 + install ($300-$400ish)... They make a big difference off the line.Gears installed should be around the same price as a TB to purchase. I would check AmericanMuscle for some more opinions and reviews.
Agreed unless you have a 6 speed I'd stick with a 3.73 or 3.90I would go with 3.73 or at most 3.90 not 4.10 ur cars mpg will go down the drain
That's less than I paid, I had bearings and all my seals replaced at the same time, I paid 650-700.About $150 + install ($300-$400ish)... They make a big difference off the line.
X or H pipeAny other mods I can do? I'm kinda stuck haha. I just want to fly
Screw the Boss 302 Intake get the Cobra Jet intake and throttle body!X or H pipe
Boss intake manifold
Aluminum driveshaft
70mm flux capacitor
Drag radials
LT headers
Front/rear sway bars (if you plan on turning LOL)
If you want to spend 1300$ for the cobra jet intake lolScrew the Boss 302 Intake get the Cobra Jet intake and throttle body!
