1 - 3 of 3 Posts
Discussion Starter · #1 ·
I think I might of found out why my shifting is a little rough (auto), to much fluid, what would be the best way to get some out, probably just get under, unscrew the pan and let some leak out?
just check the manual on how to read the dipstick. to drain it you just unbolt the back bolts of your trans pan and then a couple on the sides and some will drain out after you think its been enough check it how the manual says and add as nessesary.
drain it all that way you can get yourself an oil change while youre at it, then just put in what the manual says.
1 - 3 of 3 Posts
