1 - 2 of 2 Posts
Discussion Starter #1
So.. I recently had my 07 gt's transmission out of the car to install a new clutch set and slave cylinder. After completing the install and reinstalling the transmission, I developed a 2nd gear grind immediately following the install. At that time,2nd would only engage (without grinding) either when rev matched or being "babied" into gear. So, I find a used transmission with fairly low miles, in hopes that my 2nd gear issue would be solved.... Wrong!
The new-to-me transmission is doing the same thing. However I will say that its not near as bad as the previously installed transmission. My main thoughts right now are that there must be a problem somewhere else that may effect the 1-2 and 3-2 gear change. I know 2nd gear is a weak link in these tramsmissions, but it's just too hard to believe that the problem isn't stemming from elsewhere. Someone help me out!!
1 - 2 of 2 Posts
