1 - 20 of 23 Posts
Discussion Starter · #1 ·
So every time I drive my car, my tranny whines constantly! It drives me insane. I have no clue how the hell to fix this issue. Is it possible the b*tch is going out? Ahhh help
Sounds like a dumb question. But I know people dont always think of the obvious. When was the last time the fluid level was checked?
My old 99 auto tranny started acted like that about 90k miles, about 120k it started shifting realllll hard from 1-2, at 140k I sold it, still shifted just a bit hard and believe the new owner rebuild the teanny and is still out there pulling strong
Ok, the main thing that i know of that causes gears to whine like that is the mesh or lack of fluid. What fluid did you put back in when you changed it? and when you changed it did you drain all the fluid from both the tranny and the torque converter? how much fluid did you put back in there?
Mine does the same thing and what my mechanic told me was that in the tranny there is a planetary gear and since the lower gears aren't used as much it whines. He said that it won't hurt anything but the only way to get rid of it is taking it apart and changing it.
Discussion Starter · #11 ·
That's a project... I'd rather get someone to change it for me. But prob a stupid question but what would you change it too?
That doesn't sound dumb to me, actually, because you'd think that if it was the transmission it would sound (from the driver) more like its on the passanger side. and the power steering pump is right there around the floorboard too right?
does the whine get worse when you're steering?
does the whine get worse when you're raising RPMs (but no load on the transmission)?
or
does the whine get worse when you're driving (and progressively with more load on the transmission)?
Discussion Starter · #14 ·
or
In all honesty, it's all 3. Should have guessed about the power steering
Discussion Starter · #17 ·
Yea, i'd see about checking out the power steering first then. do you have a haynes manual?
No but I should get that. It's very helpful.
---------- Post added at 06:03 PM ---------- Previous post was at 06:02 PM ----------
Hey joe you ever get to flushing you Power Steering or na
And no I haven't. That sh*t looks black lol. I really need to get it flushed
I think it's the gear itself but not sure exactly. I don't really care though cause I plan on eventually swapping in a 6 speed
Bro flush it! let's get a cruise together, I can have it flushed in 15-20 minutes, finally back to being able to do some cruises and get out more
1 - 20 of 23 Posts
