1 - 20 of 27 Posts
Discussion Starter #1
Hey guys. I just got my first car. Its an 83 5.0. I put a different 302 in it and a tremec 5 speed from a 88 gt in the car. The car i got the trans from had been rolled 3 times. Anyways, as soon as i put the car into 3rd gear, i heard a whine/howl that sounds like its coming from the trans. Does anyone have any ideas what it could be and how to fix it on a low high school budget!
Discussion Starter #3
Its full on fluid and no i dont think so..? I just ordered the tranny fluid that the local parts store suggested to me and put it in
---------- Post added at 08:56 PM ---------- Previous post was at 08:53 PM ----------
And its a bit of a pain to get it into reverse. Is the reverse thing normal with tremec's?
Discussion Starter #7
Ok sounds good. Im gonna try it within the next few days. If it doesnt work then i will let you know
Sounds like it could be a bearing and with the reverse problem try putting it into second and then reverse and it sometimes it will go in easier
deadsp0t said:
Pretty sure they call for synchromesh, it's made by GM. My Tremec 3550 called for that. They are much more mechanical feeling V. a T5.
Not synchromesh, the t5 calls for dex/merc AT fluid. I got a warning label with mine that use of synchromesh would cause damage and void the warranty.
jwhayne0001 said:
Got an aftermarket shifter? I put a pro50 on my t5 and 3rd whines like a super charger and from what I read it's normal
I have a steeda tri-ax in mine. It whines in first and second.
I have a rebuilt t5z out of a 95 cobra and pro 5.0 short throw and use valvoline max-life ATF fluid and I don't have any issues or whine in any gear!!
Discussion Starter #16
Ya but thats a newer transmission. Possibly tremec made some upgrades to prevent the whine with a short throw shifter?
That's true and my Trans doesn't have many miles on it and I put hardened gears and stronger synchros in it! I would agree with previous suggestions change the Trans fluid and see if that helps
Discussion Starter #18
Ive also heard from my dad that it could possibly be my syncros? Is that a possibility?
If it whines in gear then it is not your synchros. Synchronizers are only used when shifting from gear to gear. If it shifts up and down through the gears smoothly your synchros are fine. If you have difficulty shifting from gear to gear or have grinding issues then you may have a bad synchro or bent shift fork.
---------- Post added at 08:30 PM ---------- Previous post was at 08:28 PM ----------
About shifting problems it could also be that your clutch may not be disengaging all the way
1 - 20 of 27 Posts
