1 - 6 of 6 Posts
· Registered
If its auto and your staying auto it will work, if manual swap from auto it will have to be changed
---------- Post added at 09:14 PM ---------- Previous post was at 09:13 PM ----------
I've done that very same swap, but you need to change the rear end too the 7.5 won't survive the torque of the v8
· Registered
Just remove it, set your drive train in place, then you will figure out which set of brackets will work. I had a 91 gt donor car, then swapped it to a 88 convertible. I just finished swapping it from manual back to auto so I could use the manual in my hatchback
---------- Post added at 10:28 PM ---------- Previous post was at 10:27 PM ----------
Oh yeah, use a small floor jack on wheels under tailshaft of trans for guidance and height adjustment
1 - 6 of 6 Posts
