1 - 16 of 16 Posts
Discussion Starter · #1 ·
I have a 01 ft that was made 08/01.anyone know what tranny cam in that.I know the tranny was changed in that time of production.?
---------- Post added at 04:43 PM ---------- Previous post was at 04:42 PM ----------
2001 gt I mean.
2001 gt I mean.
If ur shifter self centers its a 3650 if not t5 my 01 has a t5 but was made in march
In order to identify what kind of Mustang transmission you have, you need to check the door tag on your driver’s side door jam. If you look down to the bottom right of the tag, you should see an area labeled "TR." Underneath this label there are 5 letters and numbers. The only one that we are concerned with is the first alpha-numeric character which corresponds to your Mustang Transmission.
If you have a 6 as your first digit, you have five-speed manual, T-45 OD Mustang Transmission. This is the standard Mustang transmission that is found in 1996 to Mid-2001 Mustang GTs as well as 1996 to 1998 Mustang Cobras. If you have a 5 as your first digit, your car came with a T-5 OD Mustang transmission. Finally, if you have a K as the first digit in the "TR" code, you have a TR-3650. This Mustang Transmission is found in mid-2001 to 2004 Mustang GT, the 2003 and 2004 Mach1 and the 2001 Cobra. The 2005-2007 manual Mustang GT' also has a T-3650.
---------- Post added at 07:30 PM ---------- Previous post was at 07:30 PM ----------
thanks to AM ^^
Discussion Starter · #6 ·
I looked and it has 05 on the door.??
---------- Post added at 07:41 PM ---------- Previous post was at 07:39 PM ----------
It says t05
How is this tranny??compared to the t5 or t45??
The 3650 is the stronger tranny, it does have its known problems (cold notchy shifting, noisy shifter, etc)..If u never changed your fluid before, drain it out, and full with 3.2q of Mobil 1 synthetic ATF, there's a TSB about how the 3650 were overfilled from the factory
1 - 16 of 16 Posts
