AbsolutelyIs it worth getting a tuner ?
I currently have
-BBK long tube headers
-flow masters X pipe
-k&n intake
Im sure this don't matter but 3.73 rear gears stage 3 clutch and t56 swap
Thanks !
What will it improve tho? I just don't wana spend 400 and then feel as if its not worth itAbsolutely
If you get the Bama tunes from American muscle which I would recommend, then they will make you a custom tune for your car with all the mods you have included. It will pretty much tie them all together so your car perform the best it can with what it has. I have one and it was probably the best money I ever spent.What will it improve tho? I just don't wana spend 400 and then feel as if its not worth it
Yea i have heard nothing but good things about them. So what it dose is it ties the mods together and helps my performance ?If you get the Bama tunes from American muscle which I would recommend, then they will make you a custom tune for your car with all the mods you have included. It will pretty much tie them all together so your car perform the best it can with what it has. I have one and it was probably the best money I ever spent.
Is diablo sport just as good as bama ? I see alot of them used in CL im most likely gonna go with bama just wonderingExactly. It's a really good mod and one of those mods that the more parts you put on the more it helps you. Plus you have the 3.73 gears so unless you had your speedo corrected the tuner comes with n option that you can put in what gears you have and it will correct the speedo for you. Also if you have n o/r x pipe you can shut the rear 02s off so you don't throw an engine light for not having the cats without mil eliminators.
Sct sounds like the way to go, Thanks for the help & knowledge guysI can't really say for the stang I went with the act itsx
---------- Post added at 12:53 PM ---------- Previous post was at 12:51 PM ----------
I honestly can't say for the stang I went with the sct itsx but I did have the diablo sport in my old srt4 n it really woke it up. Most of the handheld tuners from my understanding are pretty much the same they just have a little more options . Used is a decent idea if they are unmarried from the previous car but with American muscle you get free tunes for life so spending the extra couple of dollars is worth it if you plan on doing more performance parts in the future.
I am looking into buying a tuner and the tunes are done by MPM More Power Mike and it says he is sct certified. Has anyone ever heard of that?Yea i have heard nothing but good things about them. So what it dose is it ties the mods together and helps my performance ?
