? Your not making sense.Soccerluvr4 said:Higher octane gas can be compressed more, so that means if you are tuned for it you get bigger combustion which = more power... That's just the basic principle behind it.
Your lost sonSoccerluvr4 said:A higher octane gas has the ability to be compressed more (or higher, whichever word you want to use). So when your cylinder compresses say 93 octane it can compress more than say 87 octane. What happens when something is compressed more and ignited? It makes a bigger explosion, and a bigger explosion means more power. But if you are not tuned for it then your car will still compress the same amount, which means that it wont matter if it is 87 or 93 because the compression is the same. Simple Chemistry and Physics
I'll give that an A+Sanguin said:You're both right, but he is more so. Higher octane allows more compression of the fuel. More compression equals more release in power when it's combusted.
Yes, you can't add more static compression, but when you play with timing, you can change at what part of the piston stroke the fuel is ignited. That is what tunes do. The more detonation prevention to the fuel, the more timing can be advanced and previously untapped power can be utilized. Advancing timing increases cylinder pressures and you need the extra octane to prevent detonation.
What does it mean to advance timing? You're making the fuel combust before the piston has reached the top of its stroke. This means you have to actually compress the expanding gases, increasing cylinder pressure and thus the resulting pressure against the piston on the down stroke. This extra pressure on the pistons down stroke generates more power.
Nerd mode activated!! Jk that was informational actually thank youYou're both right, but he is more so. Higher octane allows more compression of the fuel. More compression equals more release in power when it's combusted.
