1 - 1 of 1 Posts
Discussion Starter #1
I have a 94 mustang, all turn signals work except the front drivers side signal, I know it's not the bulb or socket because when I turn on the hazards it works but is real dim, also when I turn the headlights on at night it will work but is real dim but with out the headlights on It does not work, also when you do turn the drivers side signal on it will blink faster than when you turn on the passenger side. So I changed the turn signal switch and now it works without the headlights on just once again it is dim and still is blinking faster than normal
1 - 1 of 1 Posts
