1 - 6 of 6 Posts
Discussion Starter · #1 ·
Hello all,
I've been having a weird problem, I have an 06 mustang GT. The first sign of this happening was when I got off the freeway after driving for about an hour, put the clutch in at a light and the engine died. It would not immediately start, I turned on the hazards got out and opened the hood, did not see anything out of place. I then got back in the car and tried to start it and it fired right up. Drove another few miles to work just fine. Drove home that afternoon with no issues.
That night i went to leave my house, started the car and turned on the headlights as it was dark. The car immediately died. I had someone pick me up and I got a new battery. Installed the new battery, turned the car on, let it run for a few minutes and had no issues for a few days.
A few days later (today) I started the car, and went to turn on the headlights and it died again. I turned off all electronics in the car and let it run for a few minutes and drove to lunch with the headlights off. (about a mile away). Got back in my car minutes later and it starts and the headlights come on no problem.
Any advice as to what would cause this is appreciated. I'm going to replace the alternator this afternoon (as it's 10 years old) and check as many grounds as I can find.
Relevant info: I recently rear ended someone and had to have repairs done. One of the headlights was replaced. I got the car back from this about a month ago and this issues first popped up a few days ago.
Thanks!
Banned
Check the grounds on the radiator support. Same thing happened to my 06. It was a bad ground on the left side radiator support. These things don't like bad grounds.
Discussion Starter · #3 ·
Thanks a lot, Will do, that was something that was replaced in the accident. Was it a ground coming from the headlights? Was it corroded? Loose?
Discussion Starter · #5 ·
Ok awesome, thanks soo much. At lunch today I noticed one of them was a little loose. I'll take a close look
1 - 6 of 6 Posts
