You need to purchase the Roush Phase 1 to Phase 3 upgrade kit. Comes complete including the voucher for the Roush tune. I happen to have found one on eBay new at a steal of a price. Just waiting for the spring to install it. It comes with CAI, 80mm pulley, smaller belt, external fuel pressure regulator, plug and play wiring harness. Sold elsewhere and not just from RoushI have a 2013 Roush with a stage 3 supercharger & I would like to upgrade it to get all that I can get out of it in terms of horsepower. What mods would I need to do?
Are you running 91 or 93 octane gas in the Mustang?Everything is stock. I actually found out that it is phase 1 supercharger.
It needs more than just a tune unfortunately. A stock Stage 3 Roush is lowered with upgraded suspension, upgraded rear control arms, 20x9.5 wheels w/P275/35/R20 tires on all 4 corners. There are 2 kits that can be purchased, a phase 1 to phase 2 which is basically the CAI and a tune, they give a pulley and belt but those are for the '11-'12 Roush mustangs and a voucher for Roush tune to upload. This phase 2 kit will give you 625HP at the crank and 525 lb-ft of torque. There's also the phase 1 to phase 3 which supplies an 80mm pulley and belt, CAI, fuel booster module, plug and play wiring harness and voucher for Roush tune to upload. This kit will give you 675HP at the crank and 585 lb-ft of torqueAre you running 91 or 93 octane gas in the Mustang?
Phase 3 is the logical upgrade. I have used VMP and AED for tunes, I prefer AED. You say the Mustang is stock outside of the Phase 1 Roush kit correct? If so I would highly recommend some traction mods. The stock 245 or 255 tires (depending on Mustang package from Ford) and suspension components are not enough to put the power down.
Not sure if you miss read my post or are agreeing.It needs more than just a tune unfortunately. A stock Stage 3 Roush is lowered with upgraded suspension, upgraded rear control arms, 20x9.5 wheels w/P275/35/R20 tires on all 4 corners. There are 2 kits that can be purchased, a phase 1 to phase 2 which is basically the CAI and a tune, they give a pulley and belt but those are for the '11-'12 Roush mustangs and a voucher for Roush tune to upload. This phase 2 kit will give you 625HP at the crank and 525 lb-ft of torque. There's also the phase 1 to phase 3 which supplies an 80mm pulley and belt, CAI, fuel booster module, plug and play wiring harness and voucher for Roush tune to upload. This kit will give you 675HP at the crank and 585 lb-ft of torque
9 out of 10 I misread hahahahaha but I saw logical and thought tune and not physicalNot sure if you miss read my post or are agreeing.
Yea I was reading that and wondering, no worries hahaha.9 out of 10 I misread hahahahaha but I saw logical and thought tune and not physical
