1 - 5 of 5 Posts
Discussion Starter · #4 ·
The O-ring that goes there is mounted in the water pump. I am not sure of the # but Autozone has it listed as
FEL-PRO Water Pump Gasket 36082
  • Part #36082
  • SKU #562285
304407
Its not mounted in the water pump I took off the water pump and then this gasket and the gasket has a metal ring so do you have any idea what it is called or the part number because I can't find anything.
View attachment 304407 Its not mounted in the water pump I took off the water pump and then this gasket and the gasket has a metal ring so do you have any idea what it is called or the part number because I can't find anything.
It must be #3 in that pic don't you think? Tasca lists it as BR3Z-8527-A water pump o-ring. It should have been included with you new water pump.
1 - 5 of 5 Posts
