1 - 6 of 6 Posts
Discussion Starter #1
I painted my car with a flat clear and on top of the can it says do not cut and buff I know what buff means but cut? Like sanding?
Cutting compound. Used to go through large blemishes in a finish when using a orbital.
So if i have that orange peal look can i still sand it?
Wet sand yes using a super fine grit paper.
Then use a really good / polish and random orbital.
Then wax...
Even for flat clear?
Hmmm. That I don't know. Sorry, missed the part about it being flat.
---------- Post added at 04:10 PM ---------- Previous post was at 04:05 PM ----------
The only thing I found online about flat clear and fixing orange peel was to adjust the spray nozzle to eliminate it... I suspect wet sanding will make it more gloss... Just not sure. May want to practice on some spare metal... Paint, clear just like you did. Then experiment wet sanding/polishing.
1 - 6 of 6 Posts
