1 - 20 of 23 Posts
Discussion Starter #1
Buying some heads when I get my taxes this year don't know what to get
I have a brand new 308 short block I am building up using my x303 cam gt40 intake manifold and 24lb injectors stuck between choosing the head somebody help eventually I want 500 to the wheels and not much more
And my car has 4.10s and a t5
My dad is using afr 185r heads and they made a HUGE difference
---------- Post added at 01:09 PM ---------- Previous post was at 01:08 PM ----------
Are they going to be better than track heat 185s or 170s
Afr is the best head u can get for a sbf
Banned
I have a set on my dining room table that'll be installed this Spring. I "think" from my research that they would be great for your build.
Discussion Starter #6
I am trying to get more bang for my buck I am trying to find some flow numbers between afr and trick flows 185s
My friend had some trick flows and switched to afr 165 and he said it was a completely different car
I'm curious about the Gt40 intake holding back these heads as well. The only manifold for sale on AFRs website is the edelbrock rpm 2 so I assume its the best flowing. A little expensive tho.
Your not gonna get 500 rwhp unless you do a stroker and and power adder.
I'm running a 308 with HCI , 30lb injectors and I'm at 310rwhp
My brother has a 347 stroker motor with AFR 225 heads and the Holley System Max II intake and he's dynoed in at 445rwhp
Why not just throw a T trim vortech on your already h/c/i setup? I don't think the V-3 would push enough boost for 500hp but the V-1 should.
But will the V-1 add 200 + rwhp ? That's alot of boost on a stock block
---------- Post added at 01:28 PM ---------- Previous post was at 01:25 PM ----------
The safest way would be stroker with 6-8 psi on a safe tune!
I've seen 550hp at the crank on a somewhat stock block LS1 from a V-1. I guess you'd really need a beefed up 302 setup tho. It wouldn't seem very streetable at all tho.
Yea the v-1 is rated to 20psi and that stock 302 most likely would split right down .
---------- Post added at 01:36 PM ---------- Previous post was at 01:35 PM ----------
Are your internals forged in your 308 shortblock ?
Banned
DSS Racing sells a main girdle that they claim enables a stock 302 block to handle 650+, but you will still need a good tune
Discussion Starter #20
I don't want all 500 right now just always to buy stuff to support it till I throw a turbo on it
I been reading on the afr 185s alot and it doesn't sound like they work on a stock block so that's not good for me right now since I don't have the money to buy new pistons with valve releifs
1 - 20 of 23 Posts
