Method of boosting
  • Turbo
  • Supercharger
  • NOS
  • Stick to N/A
Results are only viewable after voting.
1 - 11 of 11 Posts
Discussion Starter #1
Hi guys, a few months ago I purchased a 2002 Mustang GT with about 121,000 miles on it. Id love to make it faster, and I have already most, if not all bolt on power mods. I was thinking about boosting it but I am not sure if it is worth it with this kind of mileage. If I do boost it, will it last for much longer? It is my daily, but I really want to add a supercharger kit or Turbo charger kit. I was thinking about doing NOS but really am not to sure about the practicality and constant fill ups I will have to do. What do you guys think? Are cams a better option? Or is boosting it not so bad of an idea? If so, which method should I choose?
You could boost it, if the engine and trans run good and you know the car is healthy then I wouldnt worry about the mileage. maybe do a compression test if your worried. Best bet would be to add a supercharger and run 8 lbs or so. I would run a centrifugal with an intercooler and some good injectors and pump. I'd keep it around 400 whp or so and if you daily it dont beat it up too much I think itll live a while
Sent from my SM-G965U using Tapatalk
Discussion Starter #3
Yeah that was what I was thinking was best. Would I have to run 93 or 91 octane? Right now I'm just running 87.
93 octane at the very minimum imo. I run 93 with boostane fuel additive in my Paxton '11
if all you have is 91 it will have to suffice unless you add an additive
I cammed my 99 over 10 years ago. To be perfectly honest, the install and cost was not that much less than a procharger (at the time). I just really wanted the car to have that lopey old school V8 sound. Still enjoy it. However, the power it added was laughable. I haven't had it dynoed but based on magazines running the same mods, It would be at around 300 rwhp, which makes sense. After the install and only on a 93 tune, I was able to compete with my buddies and their TAs and Z28s. If I had gone with a procharger, I'd have been much much faster. It's your call. All said and done, the supercharger install is probably simpler, if you are working in your parking lot/garage (I don't like messing with cams, gears, and timing on ohc engines).
Sent from my SM-G960W using Tapatalk
Discussion Starter #10
Yea it seems like blower is probably the best way to go for power, and I think if I just run like 8lbs of boost it will be reliable and fun power. But how were your cams so expensive? I understand that you need injectors and some other things, but it seems like it wouldn't add up to be as much as a whole supercharger kit. I'm not trying to say you baught overly expensive cams, I'm just trying to understand why the price was so high.
Cams, cam gears, springs, retainers, rocker arms. Then you might want to keep going an either port your heads and intake and/or at least get a bigger throttle body. So I mean, it ends up kinda costly for only like 30 more rwhp than you would have with just your full bolt on and tune stuff. I don't know man. If I had to do it over, I wouldve gotten a tuner, a new exhaust, and a blower. Like I said, I love the sound and it's great. Even if I got a blower now, I'd still need to put more money in my internals if I'd ever want to push it to its full potential.
1 - 11 of 11 Posts
