1 - 15 of 15 Posts
Discussion Starter · #1 ·
So I've got a few mods to mine but I don't wanna put it on the dino till a do a few more things. I'm currently running ford racing hot rod cams, ford racing intake manifold, 62mm throttle body, airraid 95mm cai and have it all wrapped up with a tune from bama. Anyone have similar set ups that have been tested lt thoughts about where I should be?
Sent from my 0PJA2 using Mustang Evolution mobile app
325ish is what most cars with similar mods make.
Thank you
No problem! Each dyno can read different though. Some are far more forgiving than others
Discussion Starter · #5 ·
Makes sense, I plan on putting a performance MAF sensor, ceramic long tube headers and off road mid pipe then I plan on taking it to the Dino. Hopefully it will yield some respectable numbers by then
Headers will wake it up more. I've got ceramic shorties on mine with the turbo. Ceramic is definitely the way to go
Discussion Starter · #7 ·
You running a turbo on stock internals? Or have you changed things around to better support the boost?
No its a built motor. Still stock block but forged crank, rods, and Pistons. I had a whipple with the stock motor, then went with twins on a built motor and now went single turbo on the same built motor
That's solid. How expense or difficult was it to forge everything
Its not cheap but also not bad lol just depends how far you go with it
Yeah its definitely been a blast to drive. You really just floor it and hold on lol
It for sure hasn't been a overnight then. Been a lot of long nights though lol
1 - 15 of 15 Posts
