1 - 2 of 2 Posts
Discussion Starter #1
Mods, ITS A 302 BORED OUT TO 306 FORGED INTERNALS AFR HEADS WITH 1.7 ROCKERS ARP BOLTS GT 40 UPPER N LOWER INTAKE 70 MM THROTTLE WITH EGR SPACER 24 LBS INJECTORS WITH CALIBRATED MASS AIR METER ACCELL COIL AND PLUG WIRES ELECTRIC COOLING FANS HOOKER HEADERS WITH FULL EXHAUST 3.73 GEARS ALUMINUM DRIVE SHAFT TOKICO SHOCKS ALL AROUND BBK LOWERING SPRINGS ALL AROUND K MEMBER WITH AFTERMARKET CASTER CAMBER PLATES T5 WITH BULLIT PROOF BELLHOUSING SLOTTED ROTORS ALL AROUND WITH NEW BRAKE PADS AND BIGGER CALIPERS HAS SMALL NOTHING TOO RADICAL CAM FROM TRICKFLOW ADJUSTED FUEL PRESSURE REGULATOR 255 WALBRO FUEL PUMP .
XXXhp and XXXtq would be my guess
1 - 2 of 2 Posts
