1 - 7 of 7 Posts
yes, but you will lose 1.5" of width overall and you will need to swap the axles from your 7.5 to the new 7.5. in my opinion, a big waste of time, unless you are selling the 5.0.
Discussion Starter · #3 ·
Thank you. I posted this at a different site and nobody ever gave me any useful inforomation. All they told me was to swap it for an 8.8. Now I know not to waste my energy trying to remove the d#*m thing. :oops:
couple of reasons i wouldn't even consider it.
1) it's significantly narrower so you will not have the same look you have now(your wheels will be tucked in even more).
2) you will have to convert the entire brake system with it because you'll have no brakets for the disk brake sytem, nor will you be able to reuse your old axles because they aren't even NEAR the same length. (79-93 and 94-98 can KINDA get away with reusing, same with 94-98 and 99+, but you cannot mix 79-93 with 99+).
if all you want from it is the t-lok, then yank it out and put it in the 02..it won't be that difficult and if you don't want to chage gears you can do it yourself and you shouldn't run into any issues...but one... your 82 didn't have abs, and most likely your 02 does, so you'll be missing a little part of the diff that is used for abs..not a biggie..you just remove it and you'll lose abs to the rear brakes. it won't harm anything, but your abs light will come on(pull out the bulb ;) ). so if that's something you care about then you might not want to do that.
but if you don't care(cuz you'll still have brakes) then you can do that yourself in an afternoon.
matt
Discussion Starter · #6 ·
That is all I wanted was the T-Loc. I will buy gears to go with it soon. I have the 82 (project car) just sitting around right now. The rest of the rear end will be scrapped. I don't have abs so that will not be an issue. If the T-Loc is a direct swap then that will save me a couple hundred.
1 - 7 of 7 Posts
