Stage 1
I made a while back.
What ever the last major mod is will
seem like the missing link... That means that if you do all but the cam, then
decide to do the cam, it will seem like the cam added the most HP. But a cam
alone is good for maybe 15 HP on unported heads/intakes, (not SPI though!)
but it would add maybe 25-30 if changed last. All the mods work together...
the stock cam will hold back the porting and unported heads/intakes will limit
the HP produced by a cam swap. (SPI is a great candidate for unported heads
and new cam, the stock head flow is awesome!)
It is well worth it to change the cam! Also easier to do when you have the
heads off there, as most of the junk that you remove for a cam swap is
removed when you take off the heads. But you can change a cam with the
heads on, and the engine stays in the car too. Check out the shop manual on
this procedure.
If you have any questions or think something should be added or moved please post. Please keep this on topic as well.
- Dual Exhaust (2.25" for Naturally Aspirated Cars and 2.5" for Blown Cars and some big NA strokers)
- Rear End Gears & Traction-Lok (3.73 for Manual & 4.10 for Automatic)
- Cold Air Intake
- Underdrive Pullies
- Short Throw Shifter (5-Speed) or Shift Kit (Automatic)
- Torque Converter (Automatics)
- Suspension Upgrade (Lowering Springs, Shocks & Struts, Rear Sway Bar and Strut Tower Brace).
- Throttle Body (94-98) with crossover tube matching.
- Custom Burned Chip, but most do not need this until Stage 3.
- Ported and Polished Upper Intake, Lower Intake & Heads
- Custom Ground Camshaft
- Pushrods and Springs
- Ignition System (Only needed if Forced Induction or Nitrous is used)
- Fuel System Upgrades (190/255 lph fuel pump, bigger injectors & adjustable fuel pressure regulator)
- Custom Chip necessary at this level for max power! Usually worth at least 10-15 RWHP and mucho low end torque.
- Built 3.8 or 4.2L Engine (big bore best
- Supercharger, Turbocharger, Nitrous
- Forged Internals (sic) Forged rods and pistons are a good idea.
- MAF (all years) and TB (99^) stock MAF is adequate before this.
this procedure.
