The pump is on the front left hand side of the block near the bottom. you'll see the rubber fuel line going thrugh the left hand side of the inner fender, where it connects to a steel tube that runs along the frame rail to the tank. between the pump and the inner fender is where the filter should be, if it isn't, put it there. this will save the pump from being destroyed due to deposits in your fuel damaging the diaphragm. most of these cars usually have the filter after the pump, at the top of the motor near the carb and distributor. this is probably why you need a new pump. the parts are cheap and fairly easy to install if you have some basic mechanical knowledge. good luck.
