1 - 9 of 9 Posts
Discussion Starter #1
Water is dripping alot from the part of the pipes that connect to the end tail pipes when when i start my car. Any ideas why?
It is condensation from the engine and should only last a couple of minutes. If it continues after warm up, you may have a blown head gasket or cracked block. Look for milky residue under the oil cap, and if you can, look into the oil cap opening or run your finger around the inside the filler hole and see if you remove any milky residue. DO NOT use any kind of engine block sealer or stop leak, you will be causing more problems than you want. Stop leaks have been known to clog up radiators, thermostats, and heater cores. restricting the flow of coolant
Get a Haynes Repair Manual at the local Auto Zone or auto parts store in your area. It will troubleshoot and show you how to fix your vehicle. Also on the Auto Zone site has a section for vehicle maintenance. Just browse thru it.
http://www.autozone.com/servlet/UiBroker?UseCase=S001&UserAction=viewSimpleDiagInfo&Parameters=info
Check your oil and see if you see any while stuff on the stick or in the oil, before you start it up. That is from a cracked block. If so then get some K&W block seal, not the other cheap stuff, and use it before it gets worse.
In cold weather some water coming out is normal condensation. But if it continues after it is fully warmed up it must be coolant leaking into the engine from a head gasket or intake manifold gasket. Look at your engine oil dipstick for water mixed in with the oil. See if there is oil in the coolant.
Depending on humidity and such, it's just condensation. If you also experience white smoke. then you may have a water jacket leak.
1 - 9 of 9 Posts
