1 - 20 of 28 Posts
Discussion Starter #1
Im currently working with a stock 302 besides the basic bolt-ons (CAI, Pulleys, Headers etc.)....I came across a brand new Edelbrock RPM Performer Cam from a friend who I traded with for 24lb injectors..but anyways the cam specs are .496/.520 lift with 290/300 Duration pushing against flat tappet hydraulic lifters....My question is how would a cam this size perform with gt40 heads. I also have matching edelbrock sure seat valve springs retainers,seals, and locks that will be replacing the stock valve springs on the gt40 if its worth the swap from the stock e7 heads. Help Me Out!!
Yeah that should be a good swap, I just got upgraded valve spring and retainers put in mine. Cost like 105 from our local shop for the changeover
Banned
Is there any other or more simple way to check my ptv without havin to put clay on my pistons?
It can be done with the engine assembled, but it is not really easier.
You will need to bring the piston on the cylinder you are checking up to TDC using a brass piston stop tool that threads into the spark plug hole. These tools are usually included in camshaft degreeing sets, but they can also be purchased separately
First set up a dial indicator on the valve spring retainer with the valve closed and then rotate the engine in its normal direction until that valve is fully opened. Record the distance the valve moves.
Bring the piston in that cylinder back up to TDC using the tool described above.
Remove the rocker arm, valve keepers, retainer and spring. With the piston on TDC the valve should not drop too far into the cylinder.
Set up the dial indicator on the valve tip again with the valve held up in the closed position. Slowly move the valve down until contact with the piston is made. Record that number.
You know from your first measurement how far the rocker arm opens the valve.
From your second measurement you know how far it is to the top of your piston. Subtract the first measurement from the second to see how far away your piston is when the valve is fully opened and the piston is at TDC.
It can be done, but the hassles of checking each valve in each cylinder this way and the time involved make it easier to pull the head and clay the pistons.
Peak opening will probably occur before tdc, dont forget about the duration.
Banned
True, but any contact will most likely happen with the piston at TDC when it and the valves are closest proximity.
Banned
I know, I know that's why it's best to use clay. :)
Not sure I understand your reasoning here. :confused:
A dial indicator is much more accurate than clay and if you have the piston at its highest possible point then you will get the most accurate reading.
Clay is sufficient, but not all that accurate.
But your valves won't be fully open at tdc. The intake valve is at max lift after the piston has moved down some, so measuring ptv at tdc would be wrong.
---------- Post added at 05:45 PM ---------- Previous post was at 05:45 PM ----------
Also not disputing the dial indicators accuracy.
Banned
But dosnt the move back down faster than the valve does.so it should be out of the way.
Ps I'm not sure on this ,just asking
Banned
If the piston is moving away as the valve is going to fully open position then there wouldn't ever be an issue.
The valve train moves at 1/2 the speed of the crankshaft, so the piston would "outrun" the valve at a very handy margin.
Titus Wadicus
definatnely clay the pistons....
i ran .529 lift with gt40-p heads and shattered two pistons and punched a hole in a cumbustion chamber.
dreamstang said:
I know this isn't my thread but.is it necessary to check ptv clearance going from 1.6 to 1.7 roller rockers.b303 and gt40 p .
That will give you a .510 lift. You should be able to get away without claying yours, but I would to be safe.
Titus Wadicus
i only chimed in cause he said he would running .520 on the exhaust side.
1 - 20 of 28 Posts
