1 - 5 of 5 Posts
Discussion Starter #1
Just moved to NY and its starting to snow. Ill be leaving my car outside in the winter and probably wont be driving it. With the cold weather temperature right now dropping down to 20-30F. Will there be a problem with the plastic gas tank/fuel line/brake line/coolant hoses cracking? If so what can i do? Im from Florida and never had to worried about the winter, this is a first.
It will be fine. I live in Canada and they can handle it. If your not driving it, take out the battery and put it on a slow charger. Drain your windshield washer fluid and make sure your antifreeze can handle the cold temps. I have my antifreeze good for -35.
After that it will be ok.
1 - 5 of 5 Posts
