1 - 20 of 24 Posts
they will fit...just have to have dealer, or someone reprogram your speed sensor so the speedo stay accurate....
18" vs 19"......
different sensor set up......more high tech in the 2010+....dealer will do it for free. techs come out and takes only 5 mins. 99-04 still has the tailsahft gear....
these have more than one speed sensor.....that much more cost if they go bad later.....
still thinking about taking mine up from 19" to 20" but matched all around....
Nobody can answer the diameter question can they? Fancy speed sensor shouldnt matter if that is the same. When i get home on my comp ill try and hunt it down
never mind.....guess the techs at my dealer are story telling...sorry
but....i wouldnt have had your kind of luck....
There are tire diameter calculators all over the web. You can put in the dimensions of your tire and it will calculate your diameter. That way you can compare sizes to get close to the same.
Example. 245/45/17 = 25.68" diameter tire.
1 - 20 of 24 Posts
