1 - 4 of 4 Posts
Discussion Starter #1
My window gose down a little bit it does not go down all the way it seems like it's getting stuck has anybody had this problem
does it go down very weak like? or just goes and stops all of a sudden? if it just stops then it may be hanging up on something. mine was hanging up once at about halfway down and one day it just fell completely down took the door panel off and the arms that cross in the middle had some how got bent and broke. but if its just goin down slowly it may just be the motor goin out. i would check inside the door frame for anything and if you dont see anything id check out a salvage yard for a use motor and see if that helps
Discussion Starter #4
It don't go down snow it just gets stuck a Little bit half way I took off my door panel and it looks like 1 of the slides are bent
1 - 4 of 4 Posts
