1 - 6 of 6 Posts
Discussion Starter · #1 ·
Just ran into a passenger window problem. It will go down but not up. Just got a new motor from autozone and plugged it in and the same problem, I push the down button and the little gear will spin going down but not up. Any ideas?
It's the window regulator man my GT did had the same problem. U can get a good one at the junkyard for cheap or brand new is always good too. But definitely the regulator
Discussion Starter · #4 ·
It just started working again. So ill try to hold off for now still kinda weird tho i think how it just works sometimes and sometimes it don't.
Mine had the same problem, replaced the switch and it was like new. For mine I could play with the switch to get it to work and go up sometimes.
But as stated earlier, could be the regulator to.
1 - 6 of 6 Posts
