1 - 5 of 5 Posts
Discussion Starter #1
Hey all, just wondering if I could get some advice here. Replacing the regulator on my 69 Grandé and this happened ImageUploadedByMustang Evolution1429672843.777525.jpg
As you can tell, the alignment is way off. Anyone know a way to fix this without having to start over? I've tried wiggling and loosening bolts and arms but I'm out of ideas aside from starting over. Thanks guys!
Did you get it figured out? I feel bad there were no responses but I'm not familiar with the '69 setup. Window adjustment scares away a lot of people too. It really is trial and error. If you don't know which adjustments do what, you'll need a manual.
Sent from my SM-T700 using Mustang Evolution mobile app
Pretty much only way is to start over. When I tried to do mine I I just tightened everything all the way and adjusted from there. Took me many months and many skinned knuckles to get everything weather tight
Discussion Starter #4
I did find out what went wrong! There was a random hole which I screwed it all into but it just took a good look to figure out what went wrong! Thanks you guys.
1 - 5 of 5 Posts
