1 - 4 of 4 Posts
Discussion Starter #1
Hello all,
I'm back with another issue. My drivers side window stopped working completely as well as my rear drivers side quarter window. I read a couple of forums and found out that I can remove the window motor and replace the bushings..and that should solve the problem. I did so, but once I mounted the motor back on the mount, I noticed the mount was no longer in the correct position. The spring tension in the center was no longer in place and I now cannot move the mount back in the correct position. I have attached a picture, so you can get a visual.
One picture is the way it is supposed to be positioned and the other is how mine is now positioned. I am unsure of how to keep the tension on the mount without it collapsing back..I am not certain but is there a piece that I might have misplaced that holds the tension of the mount in place. Any help or suggestions would be appreciated. Thanks.
Discussion Starter #3
Thanks for the reply, but I wasn't clear on what exactly you suggested I should do. No worries though, I gave in and decided to just order a new window regulator motor since I didn't get any other responses to my inquiry. I guess this is a topic that not too many are familiar with. Again, thanks for your response.
just recieved this issue on mine. If you had this situation again would you change them yourselves again or just take it down to the shop
1 - 4 of 4 Posts
