1 - 7 of 7 Posts
Well first you have to open where the fluid spray from and check the hoses to see if they are okay,if fine then get like a needle and clear the spray thing of dirt
You can easily take the cowl panel of simply by pullong straight up on it. Theres no bolts involed just snap clips then you can look/inspect a little easier.
Discussion Starter #5
Thanx man, i thought it was more complicated than that
The motor/pump is at base of wwasher reservoir. have someone hit spray while you're at it. you should hear it run. if not, see if it's getting 12 volts by unplugging and check with light tester. if it hums unplug hose and see if fluid sprays out. if it does find clog.
1 - 7 of 7 Posts
