1 - 2 of 2 Posts
Discussion Starter #1
I recently found my coolant to look like transmission fluid has leaked into it and vice versa. The car was still running fine but I parked it hoping that no permanent damage has been done. I read that I need to just replace the radiator because that's the part that failed is inside of that and then flush the radiator and the transmission, my question is is that correct information if no damage has been done yet will I be able to do that.
My concern would be how does a busted radiator allow tranny fluid to leak inside of it without the tranny having any leaks/damage? But if you're sure the tranny's good, then yes, just replace the radiator and flush both fluids.
1 - 2 of 2 Posts
