Im looking to try a different fluid with hopes of some kind of improvement, I plan on keeping the OEM stuff to cover myself if the transmission decides to explode, I would like to hear which fluids people have had luck with
Can you show us where you got that info? I switched to MTG a few months ago and it is running great. However if I were to see that from Amsoil I would change it again.Amsoil no longer recommends MTG at all for the MT82. MTF only.
UnleashedBeast said:No, look at the dates...Ford back spec'd the fluid from 75W-90 to a very light synchromesh. It was a drastic change. You will be perfectly fine with MTF.
Budwise said:I noticed in some threads that i read you were recommending the MTG over the MTF for road course or hot climate. I am doing road course in Texas soooo, should i go MTG or MTF?
UnleashedBeast said:The thing to remember is, how hot the oil is getting around the piston. It can reach temps up to 300*F, and bring disaster to cheap engine lubricants during extended road racing events.Budwise said:First, thanks for being such a wealth of information on these forums. I enjoy your scientific approach and analysis.
My question must be prefaced by the following:
2013 GT w/ Brembo, I installed the Boss Oil Cooler myself, the engine is on stock tune and un-modded, only suspension mods are done.
I'm taking it to the track (road course, 20 minute sessions, 4 sessions a day for 2 days) in October and I live in Texas where its damn hot. I've been running Penzoil Ultra 5W-30 for daily use. Should I bump up to a 10w-40 for the track or should I stick to the PU 5w30?
Thanks for your response and what you do here.![]()
HT/HS (High Temp / High Shear) is the term we use to measure a lubricants viscosity at 150*C (300*F). This simulates viscosity when it's around the piston areas of the engine. 30 grade lubricants are around 3.2, while 40 grade lubricants are in the 4.3 range. The higher HT/HS is desired during long session road course events to protect cylinder piston ring to piston wall contact.
For your use, I'd recommend increasing viscosity in the engine. There is a reason why Ford recommends higher viscosity in Track Pack GT and Boss 302 engines, they know it will be used for extended session events.
The oil cooler will help control overall oil temps, but even the Boss 302 requires more viscosity during these events.
Amsoil AMO 10W-40
Amsoil EaO17 oil filter
You will want this in your transmission, in case that you are not using it already.
Amsoil MTF Synchromesh - requires 3 quarts
Hand Pump - makes it easy to get new fluid into your transmission
Want the best protection for your rear axle? Road racing is punishing.
Amsoil Severe Gear 75W-140 - requires 3 quarts
Amsoil Slip Lock - requires 1 bottle
When you are not going track crazy, it's perfectly fine to step down to Pennzoil Ultra 5W-30 again, or for mpg increases....
Amsoil AZO 0W-30
and please, do not pay cost on this stuff.
Preferred Customer
Troy
Thanks for all the info BudwiseFrom the svtperformance.com forums, PM's between him and myself. UnleashedBeast is an Amsoil rep. If you search you'll find plenty of forums he's on and he states that Amsoil now recommends only MTF, not MTG. MTG is too viscous and causes notchiness on cold starts and in cold climates. It was previously OK'd for hotter/southern climates but now they recommend MTF across the board. Mine has been doing great with MTF thus far here in Texas. Hope this helps!
If it meets those specs, then yes. But I am not sure what does. I cannot find where rp, or redline specifically state it will. Amsoil specifically states no.
The hunt continues!
Troy
