Im thinking on putting airlift v2 on my car.. what are the pros and cons of an air suspension?
Sent from my SM-N910P using Mustang Evolution mobile app
Start with the best quality bags, lines and connections that you can get. Make sure the shop that installs this system has done it many times --- successfully.How long does this suspension set up usually lasts? How do you properly maintain all the lines and fittings
If you are referring to magnetorheologic (sp?) suspensions.........they do not change "spring rate". They monitor the road and constantly change rebound and compression rates of the shock absorbers --- two totally different things when it comes to the handling and ride.See that makes sense but I wonder if the spring rates change that much if you aren't lowering or raising the car. Also super cars use constantly adjusting spring rates but those change methodically for the conditions not because they get randomly compressed.
I think that what others here were trying to say when they referred to "sloppy handling at the track." If you lower your car thinking it is going to lower your CG at the track, you've also decreased your suspension's ability to control the weight of the car with softer bags. Lowering your PSI and the body of the car is for show, not go.Well air has less psi the lower it is so it is actually softer from what I understand. This is why I'm confused about it haha.
And sorry for my incorrect use of vocally previously but that was what I was trying to refer too.
