Tick when engine is cold
15K views 24 replies 13 participants last post by  Mikeyt03
#1 ·
I just recently started hearing a tick when my is cold, and goes away after I drive a bit. Is this common? It sounds like the ignitor tick, only it doesn't do it when the car gets going a bit. I'm going to take it in to get it looked at, and check the oil level. Any thoughts? This is a 2013 gt with 7.000 miles on it.
#10 ·
Im not sure on the 5.0,,but the 4.6,,the camshafts are the last to get the oil,,so most will tick a little before warm up,,but if you hear after its warm i would get it looked at..We have a whole fleet of 5.0 f150,,they are under warranty so we dont work on them yet,,we had a few with ticking after it got warm ,,a couple turn out to some lifter issues,,and one had something to do with something on the front cover,,but the dealer fixed them
#13 ·
What weight oil are you using? I have seen a lot of post on here about people using heavier or thicker oil than what is recommended. Usually if the tick is from low octane you will not hear it at idle, and at least from my experience. I know low oil or wrong weight oil will cause this when cold. If it continues after it warms up it was could be a bad lifter. Keep us posted I have 5k miles on my 13 GT and haven't heard it yet so I have my figures crossed. I am running 93 octane from shell in it mostly.
#15 ·
I believe it started when tje dealer put 5w50 on my car this Friday
#19 ·
I use 5w30.
#24 ·
Well guys ive read a lot and seen lots of videos, is anyone experiencing this problem and found a solutuon, im doing another oil change now, i did one friday with ford racing filter and 5w50 synthetic, the one im doing now is 5w20 synthetic with oem filter, ill keep you guys updated but im maaaad worried, it could be bad engine or tsb
#25 ·
I wouldn't worry to much. I really think its a break in thing. I'm not too worried about mine.
