Knocking sound left rear
7.1K views 22 replies 5 participants last post by  Redbull01
#1 ·
Hello everyone. I m new here and hope someone can help me. I drive a 2011 Mustang GT with a couple of mods. Since about 2 weeks I'm getting a hard knocking sound from the left back. I can actually fell it on the floor of the car. First i thought my muffler is lose because I had that problem in the past but that is definitely not the problem. When we had the car on a ramp we checked everything bud couldn't find anything. Now the really strange part. It gets extremely worse when it's wet or cold outside. I'm hoping someone had a similar experience because I'm currently in Germany and there are not to many Mustangs around. Therefore it's really hard to find a mechanic here that knows what he is doing. Thanks for your help.
Sent from my GT-I9505 using Mustang Evolution mobile app
#2 ·
Mine started doing the same, but on the right side rear. I didn't get time to look into it before storing it for the winter, but mine sounds like it's a bushing or isolator going bad. Does yours happen only overt bumps or rough road, or is it at all times? And what mods do you have?
Sent from my HTC One X using Mustang Evolution mobile app
#3 ·
Hello WhoDat.
It happens mostly on rough roads. If I go over a big bump nothing happens. If i drive of a smal curve it really sound like my muffler hits the drive shaft or something. But like I said the muffler is definitely not the problem. My mods are a boss 302 intake with a jlt carbon fiber cold air intake. Headers and muffler from stainless steel. Bama tune and a 4.1 gear ratio.
#4 ·
It's the sway bar end links....Ford replaced mine just recently.
#6 · (Edited)
You can grease them with brake grease for temporary relief. It's a long standing issue with s197. The links are cheap, at least this side. Several companies make replacements and Energy makes poly bushing kits you can replace the rubber with.
I do believe what did mine in were the 100+ dragstrip launches on slicks. Took out the right rear shock, too. Ford replaced all that, nonetheless.
#7 ·
Now that you've mentioned the sway bar bushings, I remember reading about that a while back. I guess I have a good starting point when I pull mine out of storage in March haha. Thanks 5LHO.
#8 ·
Well... My front tires do that sometimes. I bugged out too. Turns out it's wheel hop/skip, whatever you want to call it. IMO it happens when half the tire gets traction and the other half slips on the road surface. Does your noise happen when you're sitting still or only when you're moving at slow speeds?
#10 ·
Thinking outside the box, you could always remove the bar until you have a solution. Drive carefully until you figure out how it affects handling...it's less of s big deal than one might think, at regular road speeds.
#12 ·
Literally, I just got my car back from the dealer yesterday, from them replacing these links and the cure is complete.
Now, I teach auto shop so, I had already thrown it up on the lift and done my due diligence under there checking the bolts, pulling the bar and silicone brake greasing all the contact points, etc. so, I knew that was the problem before I took it in.
#14 ·
The right rear shock was also blown on my car and just replaced at the same time as the links. I knew it wasn't the shock because I pulled the bar and the noise went away.
Blown shocks can make noise though, there is no doubt about that but, the links are the most common issue by far on the s197.
#15 ·
I do have to say that this is kind of disappointing for a car that has 15000 miles down and is 2 years old. The problem is that i don't have any warranty over here. I already had to replace the seat motors that normally would have been under warranty.
#16 ·
I understand your pain but, that's why I'd never buy one unless I had the dealer network to back it up. These cars are a budget sports car, people forget that.
You can buy new end links for 16 bucks each at Tousley Ford or the Energy kit for 24 for everything. It'd probably cost you more to ship it to where you are.
#17 ·
Well what can I say. It was always a dream to drive a Mustang. Since ford never sold them un Europe you don't have much of a choice. What disappointed me was the fact that I went to the dealer where I bought the car with the broken motors when I was in Florida last October. Still they refused to exchange it.
#18 ·
I geddit. I've had many brands/types of cars, all had issues of some kind or other. I have had 4 Mustangs, all 5.0s: a '68, '79, '88 and this 2012. This thing flat out smokes all the others, even the '88, which was variously nitroused, turbo'd or supercharged at different times. Can't really complain too much, even though Ford had to reconstruct the MT82 at 3000 kilometers because a cheap outsourced bearing failed on the mainshaft. Otherwise, they have happily dealt with the minor niggles like the end links that have shown up over the last couple years.
#20 ·
#22 · (Edited)
yep, just go into the top right dropdown, select the stuff you need and go looking. It bumps you back to this page if you try to link to a specific part. It's on about page 6 of the rear suspension part of the catalogue. 16 bucks each "Base w. Perf. Package" means BBP w/o means, well, base....get the right one b/c the BBP has a 24 mm rear bar and base has 22.
